Machine Vision
Showing results forĀ
Search instead forĀ
Did you mean:Ā
array to image
HI
I change a image to array in labview.
I want to this array to image.
Why dose not this change?
Can you help me please?
Message Edited by Naser1363 on 08-13-2008 01:10 PM
(5,355 Views)
Your code seems to work just fine for me.  Could you include a screen shot of what you are seeing and/or perhaps the image you are using?
Kyle V
(5,337 Views)
Hi Naser,
It might have to do with the type of image that you input from the file.  The IMAQ Create VI creates a buffer for an 8-bit image unless otherwise specified.  You could try either setting the IMAQ Create VI to something other than 8-bit, or you could try including an IMAQ Cast Image VI at the front of the code to make sure that the image type is correct.  When I ran the code with an 8-bit image, it worked fine, but when I ran it with a color image, I began to see problems.  Could this perhaps be what is going on here?
Message Edited by Wes P on 08-14-2008 07:36 AM
Wes Pierce
Principal Engineer
Pierce Controls
(5,316 Views)
Ys that is my guess too.What is the camera u r using?
(5,283 Views)
