Machine Vision
autofocus
how can I make an autofocus algorithm for a B/N 8 bit image?
is the maximum contrast the right method?
how can I obtain the contrast measurement of an image?
thank you very much
best regards
fulvio coppola
(4,568 Views)
The way typically used to make an autofocus procedure and the simplest too is trace a line profile along a side of the object under FOV and control the Std Deviation parameter coming back from the line profile procedure. Higher is the Std Deviatin parameter and more close is the focus to the right value viceversa lower is the Std Deviation and far off is the focus to the right value.
Hope usefull
Best regard
(4,546 Views)
thanks a lot
best regards
fulvio coppola
(4,540 Views)
