Machine Vision
bad image with PCI1409, Jai M10SX in Triggermode with pulse width control
I'm trying to acquire an image with the PCI1409 and the Jai CV-M10SX camerea. I am using the triggermode "pulse width control". My Labview VI creates a triggerpulse to start the acquistion and to control the acquisiton time with the pulse length.
The camera runs in ext. h lock mode and the the control 0 creates the h_sync (15,625kHz) for the h_sync input of the camera and framegrabber.
The scope signals looks fine. after the rising edge of the triggerimpulse creates the M10 the WEN impulse vor the v_sync of the grabber. The videosignals looks fine too. The signals changes with the length of the trigger impulse and the picture becomes darker.
But thats the problem now: The image in LabView ist splited into two equal images one upon the other.
And after a short time a get the failure message: Timeout bei Wartefunktion, Erfassung unvollständig!
Changes in the Max config file didn't help.
Have anybody an idea.
Christian
(3,017 Views)
Which example did you use?
Is it possible to post a screenshot of the acquired picture?
regards,
ThSa
(2,998 Views)
