Machine Vision
bayer rg 8-bit - how many bits per pixel am I looking at?
Eric,
attached.  In "pixel format' , BGRA ... is the only choice.
Thanks again.
Tim
Message 11 of 14
(1,761 Views)
Hi Tim,
I can tell from the icon that IMAQdx is accessing the camera via the DirectShow driver that Point Grey provides. Since this is a GigE Vision camera you are using(?) you should be able to see it via IMAQdx's native GigE Vision support. The main thing that would keep it from being discovered in NI software is if the IP configuration is not configured right.
Eric
Message 12 of 14
(1,758 Views)
Eric,
It's a USB camera.  Is there a way to byp[ass DirectShow?
Message 13 of 14
(1,754 Views)
No, the current USB cameras from Point Grey use a propietary interface (this will change soon with the upcoming USB3 Vision standard...) and so DirectShow is the only mechanism IMAQdx can talk to the camera. You might check the Video Mode attribute in IMAQdx (right above pixel format) because I seem to recall that Point Gray implemented some monochome modes... I'm not sure if they still do debayering in their driver though in that case...
Eric
Message 14 of 14
(1,745 Views)
