Machine Vision
c# to talk to Frame Grabber PCI-1411
I'm lơking for a code example in C# to interface to The frame grabber PCI-1411 to display a frame in "SNAP" mode. Thanks.
(4,187 Views)
The latest version of NI Vision Acquisition Software (August 2009) provides a native .NET API with some examples. The examples are installed at the following location:
 XP: C:\Documents and Settings\All Users\Documents\National Instruments\NI-IMAQ\Examples
Vista/7: C:\Users\Public\Documents\National Instruments\NI-IMAQ\Examples
-Christophe
(4,177 Views)
Thank Christophe. Do you know if I can use the NI GUI for image display but having code from my application to send a "Snap" command instead of manually click the "Snap" command ?
(4,161 Views)
The button pressing ultimately runs a function call. That could be set to run automatically, of course. Just needs a little code tweak.
Jeff | LabVIEW Software Engineer
(4,144 Views)
