Machine Vision
calibration of image area measurement
Hey,
im thresholding a grayscale image, and need to find the area of the bright region in mm\cm's. how do you use the calibration vi's to calibrae pixels in to square real world units? cheers
(3,149 Views)
well brendan,
i think that you should do it yourself you lazy langer.
(3,138 Views)
You can use the conversion VI's however I would apply a scale after calibrating your image. It depends if your looking at a 2D or 3D cross-section.
2D Particle analysis can be performed for the surface area.
Kind Regards
Steven Bird
(3,118 Views)
