Home
Community
Discussion Forums
Most Active Hardware Boards
Machine Vision
Topic
Machine Vision
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
calibration of image area measurement
Brendan crowley
Member
05-07-2005
07:38 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Hey,
im thresholding a grayscale image, and need to find the area of the bright region in mm\cm's. how do you use the calibration vi's to calibrae pixels in to square real world units? cheers
0
Kudos
Message
1
of 3
(3,147 Views)
Reply
Re: calibration of image area measurement
bennyb
Member
05-09-2005
05:26 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
well brendan,
i think that you should do it yourself you lazy langer.
1
Kudo
Message
2
of 3
(3,136 Views)
Reply
Steven Bird
NI Employee (retired)
05-10-2005
08:37 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
You can use the conversion VI's however I would apply a scale after calibrating your image. It depends if your looking at a 2D or 3D cross-section.
2D Particle analysis can be performed for the surface area.
Kind Regards
Steven Bird
Kudos
Message
3
of 3
(3,116 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
