Machine Vision
camera and items need for grain color sorting
I am just starting out and am looking to build a very simple color sorter for grain.  I wish to do more later such as texture and size sorting.  I need advice before proceeding with some purchases.  For a camera I am looking at the gigE Vision camera spec, but what type should I be looking at ( line scan or area) also will gigE Vision be fast enough or do I need to be looking at 10GigE Vision.  Also for trigering the camera in this operation what would be an appropriate trigger.  The grain will be running down a chute in in a near continous stream.  Any thoughts or locations to get a better feel for this would be great thanks
(3,906 Views)
It sounds like this would require a little more in-depth information in order to determine what might be best for your application needs. I would suggest that you contact National Instruments directly so that all the necessary information can be obtained and discussed.
-Zach
(3,889 Views)
What is the speed requirement? In other words how much time is given to process an image? What are the details that you need to inspect?
(3,884 Views)
I would like to analyze somewhere between 70,000 and 120,000 kernels per second.  I want to anlalyze the kernels for color and shape.  however I could do the shape and color sort in separate runs.  I realize I will need multiple channels to realize this speed but using a single lane (two cameras one from the back and one from the front) I would like to achieve 20000 - 30000 kernels per second.  Please advise as to your thoughts
(3,811 Views)
This looks like a good application for the new FPGA / cameralink combination that was demoed at NI Week.  That is about the only way I can imagine you could analyze each kernel at this speed.
Bruce
Bruce Ammons
Ammons Engineering
(3,801 Views)
