Machine Vision
camera file generator manual
Hi Antoine,
We are using JAI GO5000M-PMCL on the 1433.
We received the camera files from JAI.
NI doesn't have them. But JAI do.
I seen someone already sent them.
But I can send them over if you still need them. We used them for the camera evaluation.
Our application is actually on the 1477. So we had to spent some time on sending commands directly.
It is a lot more work to get that sorted out.
Sorry but I can't share this part of our application.
Thanks - Amit
Amit Shachaf
Message 11 of 15
(1,050 Views)
JAI has a tool that allows direct parameter setting on this camera. I would get in touch with them directly to ask access to this tool.
Message 12 of 15
(1,042 Views)
I'd be very interested to have the right .icd file.
The one linked above does not enable to change all parameters.
Message 13 of 15
(1,022 Views)
Here are the camera files I have tested..
I am using Vertical binning of 4. I did the change in the camera file generator.
The original files from Jai are also there.
Amit Shachaf
Message 14 of 15
(1,009 Views)
I also like to add that we have used the camera control tool to setup the camera.
It lets you see the command the tool is sending. Then you can integrate to the camera file generator the same commands.
Thanks - Amit
Amit Shachaf
Message 15 of 15
(1,004 Views)
