Machine Vision
can't find vision acquisition express VI in control palette
You need not measure to distinguish between them. A 5 rs will have a thick "5" engraved on it. If you can get a nice uniform lighting you can also use a OCR.
Message 21 of 45
(1,697 Views)
But what all functions should i include ? thresholding, particle filter ,pattern matching or golden template ?? when using golden template can i compare the captured image with many reference images ??
Message 22 of 45
(1,696 Views)
OCR
Message 23 of 45
(1,690 Views)
An error is occuring
1074395247
Message 24 of 45
(1,679 Views)
After doing what you get this error. Can you give more details and info?
Message 25 of 45
(1,677 Views)
Message 26 of 45
(1,675 Views)
**** Double post*****
Deleted.....
Message Edited by muks on 01-08-2010 04:57 PM
Message 27 of 45
(1,674 Views)
the error occured when i  tried running the OCR example(express).vi  provided in the examples
Message 28 of 45
(1,673 Views)
In Vision assistant will the functions thresholding, particle filter and golden template solve my issue of coin sorting
Message 29 of 45
(1,666 Views)
It should work. try something.
Message 30 of 45
(1,664 Views)
