Machine Vision
can`t open vision builder 2011
I have some problem about vision builder AI 2011
please help me!!!
Log:
#OSName: Microsoft Windows XP Service Pack 3
#OSVers: 5.1
#OSBuild: 2600
#AppName: Vision Builder
#Version: 10.0.1f3 32-bit
#AppKind: AppLib
#AppModDate: 07/30/2011 12:04 GMT
#LabVIEW Base Address: 0x30000000
2012-2-18 20:41:31.630
c:\builds\penguin\labview\components\LVManager\trunk\10.0\source\LVListMenuImpl.cpp(683) : DWarn: bad itemId (0)
$Id: //labview/components/LVManager/trunk/10.0/source/LVListMenuImpl.cpp#2 $
0x3082FC29 - lvrt <unknown> + 0
0x300D4FF5 - lvrt <unknown> + 0
0x300D9553 - lvrt <unknown> + 0
0x300E5E4F - lvrt <unknown> + 0
0x300E957B - lvrt <unknown> + 0
0x300E9F6A - lvrt <unknown> + 0
0x307D8167 - lvrt <unknown> + 0
0x300281DC - lvrt <unknown> + 0
0x30027FD3 - lvrt <unknown> + 0
0x30028102 - lvrt <unknown> + 0
0x30028150 - lvrt <unknown> + 0
0x00401142 - Vision Builder <unknown> + 0
0x8B560C45 - <unknown> <unknown> + 0
2012-2-18 20:41:32.287
0x300D582F - lvrt <unknown> + 0
0x300D5858 - lvrt <unknown> + 0
c:\builds\penguin\labview\branches\2010\dev\source\editor\InitMenus.cpp(3194) : DAbort: Cannot call MakeDirectoryListMenus with insAfter==-1
0x300D84DD - lvrt <unknown> + 0
0x300D956B - lvrt <unknown> + 0
I don`t want to reinstall the program,and who can tell me how to repair this problem!
TKS!
(3,879 Views)
Maybe you should try to repair the installation, but you will need the installation media.
Follow this procedure: http://digital.ni.com/public.nsf/allkb/FE6B641E86E55AF2862576DE00038001
It's the same for VBAI
Regards
(3,878 Views)
I have try it,but can`t solve the problem!
I think ,it`s the problem about LabVIEW_Runtime_Engine ,because Multisim 11.0 have the same problem!
(3,876 Views)
Do you have Multisim on your system?
Do you have LabVIEW and Vision Development Module installed. If so, do you get a similar crash when you run LabVIEW?
Christophe
(3,869 Views)
Log:
#OSVers: 5.1
#OSBuild: 2600
#AppName: multisim
#AppKind: AppLib
#LabVIEW Base Address: 0x13080000
2012-2-21 20:31:41.333
0x138AFC29 - lvrt <unknown> + 0
0x13154FF5 - lvrt <unknown> + 0
0x13159553 - lvrt <unknown> + 0
0x13165E4F - lvrt <unknown> + 0
0x1316957B - lvrt <unknown> + 0
0x13169F6A - lvrt <unknown> + 0
0x13858167 - lvrt <unknown> + 0
0x130A81DC - lvrt <unknown> + 0
0x130A7FD3 - lvrt <unknown> + 0
0x130A8249 - lvrt <unknown> + 0
0x7C80B729 - kernel32 <unknown> + 0
0x00000000 - multisim <unknown> + 0
2012-2-21 20:31:44.912
0x1315582F - lvrt <unknown> + 0
0x13155858 - lvrt <unknown> + 0
0x13154B40 - lvrt <unknown> + 0
0x1315585F - lvrt <unknown> + 0
0x13154B69 - lvrt <unknown> + 0
0x13156B9A - lvrt <unknown> + 0
0x1315956B - lvrt <unknown> + 0
0x131584DD - lvrt <unknown> + 0
(3,861 Views)
Hi Toso,
Which versions of Mulitisim and VBAI do you have installed?  You mentioned it was 2011 for both but the log files you posted show something different.  Could you please confirm the versions on both and the version of the LabVIEW runtime?
Greg-H.
(3,791 Views)
