Machine Vision
optical surface profilometry w/NI Vision?
I would be interested in corresponding with anyone doing any work with NI Vision along the lines of S.Zhang's 3D projected-light surface profilometry methods.
i.e.:
http://www.vrac.iastate.edu/~song/
http://desktorch.com/structuredLight/StructuredLIght_songzhang_PhD_Dissertation.pdf
http://mesh.brown.edu/3DPGP-2007/pdfs/Realtime_OE.pdf
http://code.google.com/p/structured-light/
Thanks!
(3,460 Views)
You might want to check out the work done by AQSense and Imaging Lab:
http://www.aqsense.com/products/3d-industrial-machine-vision-library.html
Best regards
Christophe
(3,456 Views)
I am not currently working in that area, but it is an area that interests me.  It looks like a very powerful method, and relatively easy to implement.
I would be interested in discussing it, and if you need some programming done I will be happy to discuss that as well.
Bruce
Bruce Ammons
Ammons Engineering
(3,453 Views)
