Machine Vision
captured fast moving object blurs using PCI-1408
I'm using PCI-1408 with a standard video camera (Sony Viewcam) to pattern match fast moving objects. The problem is, the images aqquired are not clear and blurs(due to movement). What can i do to improve the situation? Or can u reccommend me some other hardware to improve the image quality.
(3,082 Views)
The blur is due to a slow shutter speed. If the shutter remain "open" for too long, you will get blurry images for fast moving objects.
To fix the problem, you will need to use very bright lighting, a large aperture to let in as much light as possible, and a faster shutter speed so the camera is finished taking the picture before the object moves significantly.
If you know the speed of the object, you can figure out what the shutter speed needs to be to eliminate blurring.
I'm not sure what the capabilities of the Sony Viewcam are. You might need to switch cameras to be able to control shutter speed and aperture.
Bruce
Bruce Ammons
Ammons Engineering
(3,082 Views)
