Machine Vision
changing color of overlay
hi muks
Thanks for quick reply
I was also trying to do something similar. but this doesnt work well especially if the measurements (ie overlay count) is in excess of 100s and at the same time image is larger than 8MP (Video). when i tried this workaround i got flicker which was a bit irrrrrrritating
thanks a lot, i really apreciate your help
Tushar Jambhekar
tushar@jambhekar.com
Jambhekar Automation Solutions
LabVIEW Consultancy, LabVIEW Training
Rent a LabVIEW Developer, My Blog
Message 11 of 17
(1,772 Views)
Always happy to help tusshar.  I dont understand your above statement.Do you mean i need to optimize it ?
Message 12 of 17
(1,759 Views)
Tushar,
Take a look at this example, you can use the enumerator control to select between which of the two overlays you wish to be visible.
--Michelle
Message 13 of 17
(1,745 Views)
Hi
I am using LabVIEW 8.2.1 and Vision 8.2.1
I opened your smaple VI, Unfortunately i do not have the group terminal available for Delete Overlays
please refer to the screen shot attached.
Which version you are using?
Can i some how get this or equivalent VI in LabVIEW 8.2.1
Tushar
Tushar Jambhekar
Message 14 of 17
(1,738 Views)
Hi tushar.Just press "cltrl +b" and it should work fine
Message 15 of 17
(1,728 Views)
Overlay VIs come with the IMAQ driver. I have IMAQ 4.0 - try updating your driver to the latest version: Vision Acquisition Software 8.5.1
Does this work?
--Michelle
Message 16 of 17
(1,706 Views)
Yes michelle even i feel the problem was because of version mismatch but removing the broken wires is in no way going to affect the functionality. Hope tushar has solved the issue.
Message 17 of 17
(1,698 Views)
