Machine Vision
classification Technique
        I would like to what type of classification technique(like SVM,ANN or something else) is used in a particular vi example and how to find what of classification technique is used?
For example in Labview-Find Example-Directory structure-Vision-Function-Classification-Color calssification.vi. In this what type of classification is used and how to find it?
Thank you
MADHUBALAN
(4,422 Views)
Hi Madhubalan,
under following links you will find all the information about the VISION software and all the algorithms used in it.
(These Links also take you to further links about specific topics)
What Algorithms Does the NI Vision Software Use?
http://digital.ni.com/public.nsf/allkb/95FACD2FF7FA646D862570B7006A1E66?OpenDocument
IMAQ Vision Algorithms
http://digital.ni.com/public.nsf/websearch/D6B6B5D928C186B486256F4D00046CFC?OpenDocument
Best Regards,
Martin L.
(4,378 Views)
          I have to classify nut, bolt, clamp, washer and screw .For this I have done following steps:
1.I created classifier file using NI Particle Tranining Interface (used manual method in Preproccesing tab, Nearset Nieghbour in Engine option tab).
2. Made a VI with the help of Classification exxample.vi present in LabVIEW 2012.
But When I run the VI , it is showing following error.(error 1074396030 )
Please help me in rectifying it .
I am attaching my vi , Classifier file . Please suggest me modifications in my VI if any.
Thanks.
(3,548 Views)
