Machine Vision
color coding attribute ( IEEE 1394 )
What is teh correspondance between the value out after a get attributes with attribute input set to "color coding" and the image type? I have only a monochrome camera so I can see that color coding=1 is for 8 bits images but what stands for RGB, HSL,16 bits images etc etc ?
Thank you for your answer !
(3,329 Views)
Could you tell me the exact name of function ?
Isabelle Jean
Isabelle
Ingénieur d'applications
National Instruments France
(3,329 Views)
from niimaq1394.h:
IMG1394_COLORID_DEFAULT,
IMG1394_COLORID_MONO8,
IMG1394_COLORID_YUV411,
IMG1394_COLORID_YUV422,
IMG1394_COLORID_YUV444,
IMG1394_COLORID_RGB8,
IMG1394_COLORID_MONO16,
IMG1394_COLORID_RGB16,
IMG1394_COLORID_RGB32,
IMG1394_COLORID_RGB48
In C language, you need to compare the return value to this constances.
In LabVIEW, use Imaq1394Attribute.vi with "color coding" attribut.
Hope this help.
Isabelle
(3,329 Views)
