Machine Vision
construct ROI
Hello
I have an image that I process and I would like to allow the user to specify a ROI (a rectangle would be good) to work on.
My input is my 16 bits image (1024x768) and I would like to have as output an image which will be the rectangular portion of image chosen by the user.
Please find enclosed my image.
Thanks for your help
Message 1 of 8
(6,039 Views)
Accepted by luckyloic
Take a look at this vi.  Draw an ROI on the left image and the contents will be drawn in the right image.
Randall Pursley
Message 2 of 8
(6,029 Views)
Thank you
it works very well
Message 3 of 8
(6,020 Views)
I want to costruct an ROI from bounding Box.
How can I construct?
Please Help.
Regards
Vipin Kumar
Message 4 of 8
(5,792 Views)
Hi Sir,
I have a question for the ROI, normally when i draw the rectangle without degree, then "Global Ractangle" and "Points“ are the same, but if I draw it with degree, then it is not the same.
Do you know why ?
Thanks.
Learning from other people, sharing ! bruce.xw.zhou@foxmail.com
Message 5 of 8
(3,090 Views)
The Global rectangle is a standard, non-rotated rectangle that will fit around your rotated rectangle. The Points that make it up are the actual corner points before rotation about their centre.
The Orange rectangle here is the Points with a rotation of 45 degrees and the blue would be the Global Rectangle
Message 6 of 8
(3,048 Views)
Thanks.
So normally we define the points, then it is enough, right ?
Message 7 of 8
(3,043 Views)
Yes, define the points and the global rectangle will be automatically created for you
Message 8 of 8
(3,034 Views)
