Machine Vision
control could not be loaded in imaq vision assistant 7.1
hi
i have a problem with my vision assistant 7.1
the when to tape is not working an writes an error control could not be loaded
i reinstalled it but no change
what can i do???
thanx
(2,952 Views)
Hey mana111,
I am not sure what you mean when you are talking about the "when to tape" is not working. Is this a function in Vision Assistant that you are using? What is "when to tape" and how is it not working? Also, what does the Error say other than, "control could not be loaded"? Maybe you can attach a screenshot of what is going on, that might help. Also, please be more specific and provide more details about what is going on. Also, try to explain what you are trying to do when you get this error a little better. Without more details of what is happening, and without a good explanation, we can't help you solve the issue. Thanks.
DJ L.
(2,939 Views)
