Machine Vision
controlling one window by another one
Is it possible to control brightness and contrast of an image produced by IMAQ WindDraw by moving sliders in another window (as posssible in programs like Metamorph)? If yes how can that be implemented?
(3,196 Views)
Sure. Select which VIs you want to use to process the image, then create slider controls for the inputs. Process the original image into a temporary destination and update the display.
Bruce
Bruce Ammons
Ammons Engineering
(3,196 Views)
This sounds promisingly and I will try it out soon. Thank you very much.
(3,196 Views)
