Is it possible to control brightness and contrast of an image produced by IMAQ WindDraw by moving sliders in another window (as posssible in programs like Metamorph)? If yes how can that be implemented?
Sure. Select which VIs you want to use to process the image, then create slider controls for the inputs. Process the original image into a temporary destination and update the display.
