Machine Vision
convolute
When i use filter (particularly laplace) in my script and  create .NET code from this script with Vision Assistant Code Create ( VA, version 2012 SP1), VA create incorrect code.
incorrect code:
            // Filters: Convolution - Applies a linear filter to an image by convolving the image with a filtering kernel.
            double[] vaCoefficients = {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, 48, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1};
            Algorithms.Convolute(image, image, new Kernel(7, 7, vaCoefficients), 0);
error message:
Error1:    The best overloaded method match for 'NationalInstruments.Vision.Analysis.Algorithms.Convolute(NationalInstruments.Vision.VisionImage, NationalInstruments.Vision.VisionImage, NationalInstruments.Vision.Analysis.Kernel, NationalInstruments.Vision.VisionImage)' has some invalid arguments    [----]\ImageProcessing.cs    127    4    Vision Assistant.2008
Problem is:             Algorithms.Convolute(image, image, new Kernel(7, 7, vaCoefficients), 0);
When i correct it myself as: Algorithms.Convolute(image, image, new Kernel(7, 7, vaCoefficients));
can i compile project without error. Is there a reasonable explanation for this error?
(4,311 Views)
musakaradag,
We have found an issue with our Vision Assistant code creation creating broken code when converting filter functions to C# code. We found this issue earlier this month and are actively pursuing a resolution for this issue. I apologize for the inconvenience this may cause.
Blake C.
www.ni.com/support
(4,272 Views)
The problem has been reported (CAR# 390138) and will be fixed in the next release of the software (2013 due in June or July time frame).
In the meantime, replace the file C:\Program Files (x86)\National Instruments\Vision Assistant\CG\templates\IVAConvolute.ascx by the one attached (rename the txt file .ascx)
It will fix the issue the next time you generate the code.
Christophe
(4,250 Views)
Thank you very much.
(4,246 Views)
