Machine Vision
correct inhomogeneous Illumination
i have a problem with inhomogeneous Illumination.
I must illuminate my object from the side, so i have a light gradient from left to right.
Is there any possibility to correct this with a shading matrix or a calculated correction factor from the picture?
Best regards
Andreas Stiller
(4,219 Views)
It is not clear to me.Are you trying to acheive uniform lighting?What is the object you are trying to illuminate?
(4,216 Views)
It is a paperboard. I try to make an automatic surface inspection with the photometric stereo.
(I am searching for 3D defects on the surface)
For this i have to illuminate the board from 4 directions (north, south, west and east) and make a picture from the object while holding the viewing geometry constant.
With the image fusion of the north and the south images  and the fusion of west and east i have the possibility to calculate the 3D surface.
But for this it is important that the pictures have nearly the same and a constant brightness.
So after the image correction there should be only slight surface structures visible and not the illumination gradient.
(4,206 Views)
Did you try low angle lighting techniques using bar leds
(4,195 Views)
yes,
sure i can still optimize the illumination, but this will not be enough.
i must calculate a calibration factor for each pixel
(4,190 Views)
From what i had seen so far. U cannot exactly 100% expect the illumination to be same for each subsequent parts. U need to do histogram equilization and consider lot of other factors like ambient lightings that might affect the image, the lens aperture u r operating at, the consistency of the refction from the part u r inspecting
(4,188 Views)
