Machine Vision
detect dark spots using camera
I have taken a snapshot of a light source. I am posting a sample of
bad light source. It has dark spots in it. I just need the area of dark
spots of the circle. The processing I did to get an equalized image is
acquisiton-->extract luminance plane-->imaq mask and extract-->threshold-->imaq equalize.
i used vision assistant for the above steps.
The images are attached to this post. I did use count and find objects, but results are not
that accurate. Does anyone know a better way to get more accurate results. Just let me
know if anyone knows a better way of finding all the dark spots.
Message 1 of 17
(6,447 Views)
Hey Arjun,
How many spots were you able to locate? Could you post your script?
Andy Chang
Message 2 of 17
(6,411 Views)
Is the blue patch that you are calling as a black spot? Will the perfect image have a perfect white circle? One method you ca use is detect circles in binary image and depending on the diameter you can say whether you have any black spot or not.
Message 3 of 17
(6,394 Views)
Muks
yes a perfect image will have perfect white circle. I am attaching the code as well as
original image and snap of my output. I got this code from vision assistant. In original
image the innermost circle is what I am masking and extracting.
When you will open my output image you will see that the dark spots near the border
of circle go unnoticed. The reason could be because of no border. I need to find the area
of all the dark spots, and thats it. If anyone feeds the my original to my code you will see
the result of what I see on my output. I appreciate your help. In circle the slight dark spots
are what I am lookingto detect.
I did try what Muks suggested os using circular edge detection, the result was interesting but
not what I need.
Message 4 of 17
(6,358 Views)
Before circular detaction you can try morpological operation namely dilation and increase the iteration till you get satisfactory result. Can you attach the vi for 8.0 or post a screen shot?
Message 5 of 17
(6,343 Views)
I am attaching the snapshot of the code. I am trying some experiments.
I will keep you posted.
Message 6 of 17
(6,320 Views)
Post a good image and a bad one so that we can also work on that.
Message 7 of 17
(6,300 Views)
Ok
I am attaching the good image to thia post. Here w go.
Message 8 of 17
(6,284 Views)
And again will it be ok if I give you a solution to differtiate the good and bad? Is some measurement involved?
Message 9 of 17
(6,282 Views)
Try this
Message 10 of 17
(6,280 Views)
