Machine Vision
detect dark spots using camera
Helped? Update as I am planning to leave now for the weekend........:smileywink:
Message 11 of 17
(1,861 Views)
well. What I was trying to say was the measurement should be based on area of dark spots
or black area. If black area is more than 10% of the area of circle  then it should fail. Thats
what I am trying to do. thanks for your quick response.
Message 12 of 17
(1,857 Views)
You are filling up the holes in your code. That is what I dont want to do.
The area of black spots is the most important information I need to get.
Also the dark spots need not be in the edges of the circle. They could be
anywhere in the circle.
Message 13 of 17
(1,856 Views)
I had asked you this
And again will it be ok if I give you a solution to differtiate the good and bad? Is some measurement involved?
 Again What i had suggested detects the blak spots for sure isnt it? Do you want to overlay them?
Message 14 of 17
(1,836 Views)
Yes I want to overlay them. I am sorry if I didnt mention it.
I wanted to overlay the dark spots and also calculate the area
and thier percentage in total fibers. That is what I am planning
to do.
Message 15 of 17
(1,828 Views)
This is entirely different to what we have been trying to do so far.....
Message 16 of 17
(1,826 Views)
Muks I am sorry if I confused you. If you read my first post it said clearly what I was trying to do. I needed percentage area of dark spots in the image. Arjun
Message 17 of 17
(1,810 Views)
