Machine Vision
does LabVIEW8.2 supports USB camera for vision application?
Does LabVIEW8.2 supports USB camera for vision application?
& if support then tell me which USB camera is been supported by this version
(4,912 Views)
labVIEW supports lot of USB cameras /Fire wire cameras.But not all cameras are supported by labVIEW.First decide on the speck of the camera then see whether they provide labVIEW drivers and support files. 8.2 Version of labVIEW has nothing to do with USB camera support.
(4,911 Views)
Instead of starting a new thread you could elaborate on your application.Do you want us to suggest a suitable camera?
(4,902 Views)
yes give me the names & version of the USB camers which is supported by LabVIEw
(4,900 Views)
AVT(Allied vision technology) Provides a lot of usb progressive scan camera. If you are looking for some particular application,you have let us know abt ur applicationSmiley Wink
(4,885 Views)
My Application is Based on OCR so for this purpose i m using LabVIEW 8.2. can u suggest me some USB camera which can improve or support my application.
(4,871 Views)
Hi ddsdds,
National Instruments dose not officially support USB cameras.  We do have an unsupported driver to use USB cameras however.  The USB camera must be direct show compliant to work.  If you are looking for a officially supported camera I would recommend you to www.ni.com/camera  Any of the cameras list on this page will work with Labview.
Adam H
(4,839 Views)
