Machine Vision
drive an external device with isolated output of NI smart camera 1742
Hello everyone
I now work as a graduate project to build a vision system.
My problem is that I want to make a system of rejecting non-compliant products with a reject system manipulating by intelligent NI camera using the isolated output but I do not know how to do it.
thank you in advance
(2,905 Views)
Hello Abdelhamid,
Here is Getting Started and User Manuals for NI Smart Cameras:
https://www.ni.com/docs/en-US/bundle/372351d/resource/372351d.pdf
https://www.ni.com/docs/en-US/bundle/ni-17xx-seri/resource/372429c.pdf
For example, Isolated Output 0 is green and yellow wires of NI POWER-I/O Connector
You can use Vision Builder for Automated Inspection software to create your application easily. It is very easy to handle digital outputs using Read/Write I/O function based on your measurement.
(2,877 Views)
hello  sevincom
thank you for your reply
So for me I want to build a LabVIEW-based program using Vision Development module, I have already read these documents but I have not found a labview function to have a 24V output from the isolated output 0 as you See picture 1.
in addition for a system of 24V how can i feed it by an isolated output by plugging it to the pins high and low of the isolated output as you see in picture 1 and 2.
For me I have already worked on a program that allows the reading of an isolated input to do a processing in the program. the isolated input is plugging with a sensor that delivers a 24 V voltage when it detects an object see figure 3. And for the program see vi
But to do the opposite operation of this is what I fail to do.
Thank you in advance
(2,866 Views)
i need response please
(2,833 Views)
