Machine Vision
error 0xBFF6901B
As i wrote before, your camera is a USB-camera. NI Vision communicates with USB2 cameras over DirectShow. If you can't open your camera in "uEye_DirectShow_Demo.exe" (Or AMCap) there can be two problems:
- The connection between the computer and the camera may have a problem (USB-cabel, USB speed mode)
- DirectShow service was not installed correctly (install program package for your camera again)
Message 11 of 13
(3,048 Views)
Hi
I have started the camera with AMCap but the situation is the same. I have reinstalled the directshow driver again but the error is the same.
Message 12 of 13
(3,041 Views)
If I use AMCap software what I have to change here. There is no pixel clock for setting it like in uEye_DirectShow_Demo.exe
Message 13 of 13
(3,040 Views)
