Machine Vision
error when connecting to Allied vission Manta
First your question could be related to this error, but now i feel it is completely different so start new thread.
Because the IMAQdx session you are not passing it to subVI and hence error. Please check here how to create subvi and setup the controls and indicators as terminals: http://www.ni.com/white-paper/7593/en/
uday
Message 31 of 33
(1,952 Views)
uday, I also wanted to attach this vi, the one of the two that works. thanks.
Message 32 of 33
(1,952 Views)
You are correct. Simple solution. I'm able to pass the session out! And the camera is working thanks to the IMAQdx update. Thanks uday and AVT!
Message 33 of 33
(1,944 Views)
