Machine Vision
external trigger camera with 12 pin hirose
I have DMK 23UV024 from theimagingsource (link for cam). It requires 12 pin hirose connector for trigger. I have TTL input as my trigger pulse coming from my DG2020A data generator. I am confused which 2 pins are supposed to be used for the trigger.
Abhilash S Nair
Research Assistant @ Photonic Devices and Systems lab
[ LabView professional Development System - Version 11.0 - 32-bit ]
LabView Gear:
1. NI PXI-7951R & NI 5761
2. The Imaging Source USB 3.0 monochrome camera with trigger : DMK 23UM021
OPERATING SYSTEM - [ MS windows 7 Home Premium 64-bit SP-1 ]
CPU - [Intel Core i7-2600 CPU @ 3.40Ghz ]
MEMORY - [ 16.0 GB RAM ]
GPU - [ NVIDIA GeForce GT 530 ]
(5,407 Views)
Hi Abhilash,
I took a look at the link for your camera, and in the documentation section, I found a PDF that had info on the triggering for the camera. I'd say take a look at page 5. I hope this helps!
David S.
(5,392 Views)
Accepted by abikutn
Yes David,
The page 5 is the pin out config for the camera trigger (Ext). I assume pins 11 and 12 act as the BNC trigger +5 and 0. Am I correct ?
Abhilash S Nair
LabView Gear:
(5,388 Views)
Hi Abhilash,
Yes, it looks like pins 11 and 12 for the USB  version are the trigger lines. You would send anywhere between 3.3 and 24V to the positive pin (pin 11) and your return line would be the negative pin (pin 12).
David S.
(5,381 Views)
