Machine Vision
extract the overlay portion of an image
i use the IMAQ overlay Retangle.vi to the image,and then i want to extract the portion inside the retangle to process,how can i do it?
thanks
Message 1 of 16
(4,800 Views)
You can use Imaq extract vi for this purpose.Just feed the rectangle co-ordiantes (top,left bottom and right) defining the region to be extracted
Message 2 of 16
(4,798 Views)
Message Edited by muks on 10-16-2008 03:58 AM
Message 3 of 16
(4,797 Views)
but if it is a rotated retangle(such as rotated 45° ),it can not work well as you said
帖子被skyover在 10-16-2008 05:16 AM
时编辑过了
Message 4 of 16
(4,784 Views)
please see my another POST "How to overlay a part of image with inclined retangle "
帖子被skyover在 10-16-2008 05:25 AM
时编辑过了
Message 5 of 16
(4,777 Views)
If it the continuation with the same question then why start a new thread?
Message 6 of 16
(4,774 Views)
My suggestion would if can get the angle then rotate the image by reference to that angle and then extract.
Message 7 of 16
(4,773 Views)
Hi!
Same trouble!! I need a function so that it can extract a rotated rectangle. Extract.vi only returns a part of an image parallel to X and Y axis. I'd like to get one function that you can pass 4 point (coordinates) and maybe an angle of rotation so you get a rotated rentangle.
I know IMAQ rotate.vi does exists but it doesn't help, I need what I told before!!
Message 8 of 16
(4,376 Views)
How do you say the rotate will not help here?
Message 9 of 16
(4,371 Views)
Hi, Greg,
Do not search "ready-for-use-super-puper-universal-tool", just use suggested functions in combination:
Just starting point for you:
And result:
Now you have two images - one is extracted and masked (areas outside of rotated rectangle are filled with black. The second image is rotated and cropped to size of the original rotated rectangle. I have used fixed coords, but they should be calculated based on original size and angle (simple arithmetic).
best regards,
Andrey.
Message 10 of 16
(4,345 Views)
