Machine Vision
extract the overlay portion of an image
First of all thanks for your answers!!
Secondly, I want to explain what I'm working on in order to answer why to rotate the image after extracting doesn't help! I'm programming a pattern pointing, this pattern is moving all time in real-time, it can rotate up-down right- left and I focus the overlay rectangle on the pattern everytime (while loop) to extract that region because the pattern is changing constantly. It would be much easier for me to extract a rotated rectangle, I have thought of doing what you have told me, but I think is not working because of the design of the program, anyway I will try to make it your way.
If you know about the "magical" function I´m looking for, please tell me! Sorry if my explanation is not clear enough!
Thanks again!!
Message 11 of 16
(2,030 Views)
Thanks a lot Andrey!!! I have tried your solution in my program and I think it's gonna work!!
best regards,
Greg
Message 12 of 16
(2,024 Views)
If you have Vision Development Module 2009, you can use IMAQ Extract Tetragon. This VI can extract any 4 sided polygon from an image, including a rotated rectangle.
Ben
Message 13 of 16
(2,016 Views)
Thanks Ben! That's exactly what I needed!! Problem solved!
Message 14 of 16
(1,988 Views)
That was one of the things in my wish list.
Message 15 of 16
(1,979 Views)
 Sorry Muks! Maybe I read it too fast and didn't realized you wrote that solution!! Anyways thanks all of you guys for your anwers!!!
Message 16 of 16
(1,966 Views)
