Machine Vision
firewire extender
Hi.
My 1394a camera is hundreds meters far from computer, so I installed a Gefen firewire 800 extender. It is optic fiber based extender able to carry 800Mb/s.
When I connect my camera directly on PCI-8254R board, it run at 400Mb/s, with 30fps and 1024 x 768 pixels. If I connect camera by extender the only bus rate i can use is 100Mb/s and frames are no more than 15 per second.
Even I dont use optic fiber, but connect camera directly on the second port of externder and use the first one to send data to computer (30 cm far) I experience the same problem.
Any conflict between PCI-8254R and extender?
Can anybody understand it and help me?
Thank you very much
Antonio
(3,935 Views)
I know Windows XP has a problem with firewire 1394b.  Since your extender is firewire b, that may be your problem.
I would recommend the Prosilica patch (go to Prosilica.com, go to support, find patch for firewire b).  That allows you to run firewire b at 800 Mb/s if you have a firewire b board in your computer.
For some strange reason, I had to run the patch twice to get it working.  I ran it the first time, then used Device Manager to reactivate the firewire drivers, then ran it again.
If you only want to get 400 Mb/s, you can just follow the instructions in the Microsoft firewire patch.
Bruce
Bruce Ammons
Ammons Engineering
(3,929 Views)
Accepted by Yixiao-uncle
PERFECT!!!!
yes, You are right, I needed to install more times and reboot computer several times, but after that it works perfect.
Thank You
Antonio
(3,891 Views)
