Machine Vision
fpga
Hı. I'm using NI 1473R frame grabber fpga card and Basler acA-2000-340kc cameralink camera. After updating labview software from 2014 to 2015  I have problem with my camera. Basler Pylon configurator software shows  error in image below.Should  I change pylon software with new version or what should ı do. thanks.
(4,610 Views)
Accepted by impect
I'm not sure how your Pylon software works, but I'm not surprised if there is an incompatibility somewhere. I might try upgrading your Pylon software or any other NI software that you have. Are you using Vision Acquisition Software or any of the IMAQ drivers? You might have to update those to be compatible with LV 2015.
(4,581 Views)
