‎02-16-2010 08:08 AM
‎02-16-2010 10:21 AM
Something like that:
Andrey.
‎02-17-2010 06:59 AM
Andrey thank you very much...
I tried to convert the image into 2D matrix.. But i couldn't..
How to convert image into 2D matrix??
‎02-17-2010
07:06 AM
- last edited on
‎07-23-2026
12:22 PM
by
Content Cleaner
Andrey.
‎07-12-2010 10:35 AM
How did you integrate this filter or how does your software look-alike?
Jos
‎12-13-2012 10:40 PM
will this gabor filter code work for palmprint texture extraction in biometrics???
‎04-12-2014 03:23 PM
Thanks for your post,
but I'm new to the Labview program and I don't quite understand how it works.
Could you send me the example or explain it more?
‎04-12-2014 08:21 PM
Thank you for your help, but I couldn't understand exactly how it works.
I don't know what is wich part of it. Coul you explain, please?
‎12-01-2015 01:26 AM
Hi, Can you please send me the VI for the transfer function
‎04-10-2017 03:20 AM
Hello I want the error detection on technical surface (image processing). I will use Gabor filters to analyze 8 bit images. I do not know how to create in LabView Code, a VI for 2D Gabor filter. Input data are 8 bit images. Many thanks for your help
