Machine Vision
NI Camera File for Hamamatsu c11440-10C
I obtained recentlry new camera Hamamatsu C11440-10C (ORCA Flash 2.8) CMOS camera and tried to connect it to frame grabber NI pcie-1433 on 64 bit version of Windows 7. Unfortunately I was stacked when I checked the connectivity between them, since Camera File was not available for this camera yet. I found that NI Camera file generator could be used to generate camera file specific to C11440-10C, but I could not make it work due to the unavailability of the values for the parameters which needs to be filled.
I wonder if I could apply the camera file which was designed for the other cameras to C11440-10C as well. Ideally, I hope I can adjust the representative parameters such as frame rate, frame size (width, heigh in pixels), RTSI, binning, resolution in bits and acquisition grain.
http://www.hamamatsu.com/eu/en/C11440-10C.html
Best,
Hidenori
(5,138 Views)
Hello Mr.. Haizawa
Actually Camera file is better if being provided by the Camera makers, NI Camera File generator can be used to create a Camera file, according to the parameters provided. National Instruments,however,does not ensure the operation of the camera based on this camera file.
I hope this document will help.
http://digital.ni.com/public.nsf/allkb/E16D3364AD5D8C1C862576160075AF93?OpenDocument
best regards,
(5,114 Views)
Hi Mr. Muhammad,
Thanks for the response. As you kindly suggested, I obtained the camera file for this camera from vendor, Hamamatsu. Unfortunately, This camera file as such does not works with PCIE-1433 but with other previous frame grabbers. I will try to modify this camera file further. Specification of the frame grabber provided by the link should help.
Best,
(5,109 Views)
Dear Mr.haizawa
please let us know your progress in this regard,how things work in future.
Best of luck for your application.
(5,104 Views)
i need the camera file for hammatsu camera c-1140-22u.  i tried to generate using ni camera file generate but it does not work . i contacted to hamamatsu but they have not replied. i am using pxie 1435 frame grabber card.
(3,491 Views)
