Machine Vision
highlight option in IMAQ overlay oval
Accepted by Klemen
Hi Klemen,
Sorrily, if there is no direct option or property for this I am afraid there is no simple method to achieve this. As you said in a previous post here, you can do the trick by creating an overlay bitmap, but it would certainly require much more work that just using a rectangle with the highlight option.
Kind regards,
Izabela
Message 11 of 14
(3,680 Views)
Thank you!
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
Message 12 of 14
(3,677 Views)
How about overlaying multiple rectangles into the shape of an oval? I know that is tedious but perhaps it would work...
I am attaching an example (LV2012) that highlights any given ROI you draw on a loaded image. It is not the most efficient algorithm but it gets the job done. I just simply create a Mask from the ROI and then overlay rectangles on the mask pixels. If your process is time-sensitive, you will want to keep an eye on the processing time this takes. Depending on the shape you can make the algorithm much more efficient than pixel-by-pixel overlays. For the large red shape, it took 280ms to draw pixel-by-pixel on my laptop... so clearly not efficient on time.
Highlight ROIs
Chris Walker
Certified Labview Developer
Message 13 of 14
(2,053 Views)
And here is a screenshot of the block diagram for a pixel-by-pixel method:
Chris Walker
Message 14 of 14
(2,051 Views)
