Machine Vision
how can i configure d-Link wireless ethernet DCS 950G camera in Labview?
i m using Labview 8.2 and vision assistant 8.0
reply fast
Message 1 of 8
(5,326 Views)
Can any help me to solve this problem?
reply me fast.
Message 2 of 8
(5,315 Views)
reply me fast.
Did You really feel this will help?
Message 3 of 8
(5,303 Views)
hi muks
can u tell me how can i configure my camera in Labview.
i m having ethernet camera from D-link. the model no. is DCS 950G. this is with wireless conectivity.
but i donot know how can i acquire images in labview? can u help me.
i have Labview 8.2 and vision Assistant8.0
Message 4 of 8
(5,300 Views)
Hello ddsdds,
Is your camera GigE compliant? NI-VISION software requires that cameras meet this standard.
Someone else posted a similar question on this forum. Apparently you may be able to use ActiveX commands to use the camera. Again, I would focus on the compliance of this camera with the NI-VISION GigE protocol.
Does your camera show up in the Measurement & Automation Explorer (MAX) under NI-IMAQdx devices? The first step is to configure hardware in MAX before moving into LabVIEW.
I hope this helps 🙂
David G
Sales Engineer - SE Michigan & N Ohio
Message 5 of 8
(5,240 Views)
this camera is not giga bit etherenet cam.
and i m not able to find this cam in MAX. but i have one question that i m connecting my cam through ethernet port. so how can i find it in MAX reply
Message 6 of 8
(5,222 Views)
If your camera is not GigE compliant, it will not show up in MAX.  There is no way to get an ethernet camera to show up in MAX unless it is GigE.
Bruce
Bruce Ammons
Ammons Engineering
Message 7 of 8
(5,206 Views)
ddsdds,
If the camera is not GigE compliant, then you cannot use it with the NI-IMAQ or NI-VISION acquision software. Please follow the link in my above post for information on using ActiveX commands to call to the camera anyways.
I recommend purchasing a camera suited for industrial applications. You can find a list of NI-IMAQ supported cameras here.
David G
Message 8 of 8
(5,205 Views)
