Machine Vision
how cut a image to many part with it's boundary.
hai me yoges..im doing library robot. so the vision system of robot is very important. how to segment or cut a image into many parts by canny edge dectector ( which boundary of image) of roi.. im using vision assistant do this work..here i upload the image...give anyone got idea plz comment...IMG_0034.JPG
(4,697 Views)
i have to segment or cut each book by it's boundary..so tat i can find the book call number for each book...i really confuse for this part...or any one can suggest any other idea to segment each book..
(4,696 Views)
Accepted by yogeswaran
Have you tried using "IMAQ Find Straight Edges 3.vi" ("caliper" palette under LabVIEW or "Advanced straight edges" in Vision Assistant) ?
It should allow you to detect each book vertical border.
Select a rectangular ROI, in the middle of the image (above the books calls numbers), then, search for vertical straight edges using "Left To Right direction".
Please see screen capture from Vision Assistant, attached herewith.
Best Regards.
JC Benoit
Vision Engineer
Alliance Vision
www.alliancevision.com
(4,673 Views)
ta sir for use reply..i did the straight edge detection but i can't cut or crop each book after find the vertical edge...sir can suggest how to cut ech book...plz sir i need ur help..
(4,658 Views)
You can use "IMAQ Extract.vi" in the "Vision utilities"=>"Image Manipulation" palette, in order to extract a rectangular region from an image.
Best Regards.
JC Benoit
Vision Engineer
(4,648 Views)
because i new for labview. i got difficult to do programming..how can that function automatically detect the coordinate, to crop each book..?
(4,548 Views)
sir , can i get example LABVIEW code for my project...help me....
(4,508 Views)
