Machine Vision
how do you install the vision deployment engine
I cannot find the Serial num,ber in the kit. Where is it?
(3,395 Views)
It should be an 9 letter alpha-numeric code on your CD case. Call Ni.com/support >> select call option, if you need further assitance.
(3,395 Views)
I now understand that the part number I purchased has no serial number. I needed to select the second option to install the product directly. I have resolved this issue. Thanks
(3,395 Views)
