Home
Community
Discussion Forums
Most Active Hardware Boards
Machine Vision
Topic
Machine Vision
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
how do you install the vision deployment engine
sgraff
Member
05-05-2003
01:44 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I cannot find the Serial num,ber in the kit. Where is it?
0
Kudos
Message
1
of 3
(3,481 Views)
Reply
Re: how do you install the vision deployment engine
pavanb
Active Participant
05-07-2003
12:03 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
It should be an 9 letter alpha-numeric code on your CD case. Call Ni.com/support >> select call option, if you need further assitance.
0
Kudos
Message
2
of 3
(3,481 Views)
Reply
sgraff
Member
Author
05-08-2003
08:37 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I now understand that the part number I purchased has no serial number. I needed to select the second option to install the product directly. I have resolved this issue. Thanks
0
Kudos
Message
3
of 3
(3,481 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
