Machine Vision
how to create a grayscale avi?
Kelly -
Hmm...that certainly seems that it should read the number of frames per second correctly (although the frames per second must be an integer, so it's probably being written as 7 frames per second).  Are you using a compression filter?  Can you attach your VI to this post?
Thanks!
Greg Stoll
IMAQ R&D
Greg Stoll
LabVIEW R&D
Message 11 of 12
(1,201 Views)
Hi Kelly,
That's pretty weird.  Breaking out the cluster seems to display the proper number of frames per second on both my machine.and a test machine with Vision 7.1.0.
I'm glad to hear that you have a way around it for now!
Robert
Message 12 of 12
(1,200 Views)
