Machine Vision
how to display images real-time?
How, (using CVI, NI-IMAQ and IMAQ Vision) can I duplicate the Grab function seen in MAX; in other words, I want to display images at the frame rate of my camera (30 fps). I've come across several examples on this site, the best of which seemed to be "Performing Real-time Image Acquisition, Averaging, and Logging" (realtime_image_averaging.zip), but this example, built with LabView, can't find several vi's (IMAQ WindDraw.vi, IMAQ Convert.vi, IMAQ Add.vi, IMAQ Divide.
vi, IMAQ WriteFile.vi) needed to run it. I have LabView 5.1, NI_IMAQ 2.6 and IMAQ Vision for LabView 4.01). Please note that, although I'll accept LabView, I prefer a CVI solution.
Thanks in advance for any help.
'til next we type...
Jesse
(3,463 Views)
Have you tried the examples that ship with IMAQ and Vision? In LabVIEW, there are examples that demonstrate simple grab and display techniques. I assume similar examples are available for CVI. I don't remember what was available for the old version you have.
Bruce
Bruce Ammons
Ammons Engineering
(3,463 Views)
Yes, there are examples like that, but they all acquire, then display. I want to do what is available in the MAX Grab feature, which continously updates the display at the frame rate of the camera. BTW, I'm using CVI version 6.
(3,463 Views)
I would strongly recommend upgrading to the current version of Vision. There have been major improvements since the version you have. I suspect the examples have improved significantly also, which would probably be worth the cost of the upgrade. I have attached a simple grab and display example in LabVIEW that I saved to LV 5, but I can't be sure it will work with the old version of Vision. Since you want to use CVI, it probably won't do you much good anyway.
Bruce
Bruce Ammons
Ammons Engineering
(3,463 Views)
Upon deeper spelunking into the examples directory, I found grab and ring examples that should provide a reasonable starting point for what I'm trying to do. Thanks again for your suggestions.
(3,463 Views)
