 dineshniot
			dineshniot
			10-08-2018 07:17 AM
Hi - It would be very great , if you can tell me how to divide the inside part of the circular image into each 1 cm2 sections and further I need to find the RGB values of divided each sections using NI Vision Assistant? Since I am new bee to NI vision assistant , I couldn't find any function / tool to divide the circular image into each 1 cm2 sections.
Please do the needful at the earliest.
Dinesh
10-18-2018 12:13 AM
Hi - Can anyone please reply.
Dinesh
 BruceAmmons
			BruceAmmons
			10-18-2018 10:46 AM
You didn't get any answers because it can't be done.
I can't think of any tools in Vision Assistant that would help you do that. You would probably need to calibrate the image first, which is relatively easy, but I don't know how to divide it up the way you want to. In LabVIEW, you could generate a set of coordinates and step through them, but Vision Assistant does not have that flexibility. Even in LabVIEW, there would be issues at the edge of the circle, since you are mixing rectangular coordinates and a circular image.
Bruce
