Machine Vision
how to divide the inside part of the circular image into each 1 cm2 sections using NI vision Assistant
Hi - It would be very great , if you can tell me how to divide the inside part of the circular image into each 1 cm2 sections  and further I need to find the RGB values of divided each sections using NI Vision Assistant? Since I am new bee to NI vision assistant , I couldn't find any function / tool to divide the circular image into each 1 cm2 sections.
Please do the needful at the earliest.
Dinesh
(3,135 Views)
Hi - Can anyone please reply.
Dinesh
(3,098 Views)
You didn't get any answers because it can't be done.
I can't think of any tools in Vision Assistant that would help you do that.  You would probably need to calibrate the image first, which is relatively easy, but I don't know how to divide it up the way you want to.  In LabVIEW, you could generate a set of coordinates and step through them, but Vision Assistant does not have that flexibility.  Even in LabVIEW, there would be issues at the edge of the circle, since you are mixing rectangular coordinates and a circular image.
Bruce
Bruce Ammons
Ammons Engineering
(3,093 Views)
