Machine Vision
how to do area ratio measurement?
When threshold is applied you get this and from here on it is pretty simply. You can eliminate the black holes by applying erosion.
18263i538D31FF8062EBEE
Message 11 of 12
(833 Views)
This is easy to be done by Vision. The problem is still unsolved. I want to know the ratio of the area for each particle. If I am required to measure the black parts one by one, and then red part one by one, then I need to specify or label each particle. Then I can safely say that the two parts are from the one particle. Actually, the problem becomes more complicated when the number of particles is more than 500.
Message 12 of 12
(797 Views)
