Machine Vision
how to draw virtual line in Vision Builder
Hi i need to draw virtual point with refernece to coordiante .
i tried custom overlay to draw line but it not follwing coordinate .
i need to use my coordinate to draw line . ( and custom overlay still in pixels ?)
i have addtaced my Vbai file
(5,385 Views)
It looks like you're already using previous results for your Overlay Line Coordinates. Seems like this should work fine. You can also use an ROI step that is based on a coordinate system and use the results of the ROI step (which include the pixel coordinates for the resulting ROI) as the points for your overlay.
Please be more specific if you're still having trouble.
Brad
(5,376 Views)
Hi Brad,
Thank you for your kind reply .
now its working fine .
i got another doubt in here to change the Orgin of the image i am again doing Calibration Step.
Is that Correct way to Change the location of Orgin .
(5,369 Views)
If you change the calibration origin, all that will do is change the value of calibrated positions returned by steps, but it won't affect the pixel values, which is what the Overlay step uses. If you want your calibrated results to be referenced from a different origin, than updating the calibration origin will do what you want.
Hope this helps,
Brad
(5,358 Views)
HI Brad,
Let me try and tell you
(5,349 Views)
Hi Brad,
How to do 9 point Clibration in vision Builder.
(5,331 Views)
