Machine Vision
how to use multiple (.vbai )vision builder files in labview
hi all,
In my application i need to use multiple vbai file in labview .
if i get any example vi it may helps me lot
Message 1 of 14
(8,046 Views)
Check out the VBAI API you can use from LabVIEW to launch multiple local VBAI engines or connect to multiple remote VBAI engines. The example illustratews how to use one (there's an example for a local engine and remote engine), but it should be easy to expand the scope to use multiple engines.
<National Instruments>\Vision Builder\API Examples\LabVIEW Examples
Hope this helps,
Brad
Message 2 of 14
(8,027 Views)
hi Brad,
Thanks a lot for your reply
In that file how to passs my image and get result .
any small example ..
Message 3 of 14
(8,018 Views)
Are you wanting to acquire in LabVIEW and pass the image to VBAI and then get the results from VBAI back in LabVIEW? Or do you want to acquire in VBAI and just get the results and processed image in LabVIEW?
Brad
Message 4 of 14
(7,994 Views)
Grab image in .vbai and result in labview ,
after Doing Motion Part .
i need to call another .vbai file .
Message 5 of 14
(7,984 Views)
If you check out the example here:
C:\Program Files (x86)\National Instruments\Vision Builder AI <version>\API Examples\LabVIEW Examples\LabVIEW API Example (Local).vi
It will show you how to use the VBAI API in LV to launch a local engine, open an inspection, run it, get the resulting image and results. You can use the Enable Measurements VI and Get Measurements if you need more detailed results from the steps in VBAI. Read the documentation on all the VIs in the VBAI palette of LabVIEW to better understand how to use these VIs to accomplish your goal. Press Ctrl-H and hover over any of the VIs to get help and then you can click on the Detailed Help link, or check out C:\Program Files (x86)\National Instruments\LabVIEW <version>\help\VBAI_LV_API.chm
You had asked about Pick and Place as well. This is very application depenent. If you post some pictures, people on the foum could help with finding the item you want to pick (make sure to be specific about what you're looking for in the image and if you need to calibrate the image to pass real world coordinates to motion VIs), and the motion is dependent on the types of motors/drives you use. Here are some links to motion pick and place examples I found with a simple search:
http://www.ni.com/example/27360/en/
https://forums.ni.com/t5/Student-Projects/Robotic-Pick-and-Place-System/ta-p/3508538
http://www.ni.com/white-paper/3200/en/
Hope this helps,
Brad
Message 6 of 14
(7,923 Views)
i am using this method to Call different vbai files .
but VBAI file opening. takes so long .
in that case
I tried following method
Its Working Fine . But not able to Open multiple files.
So please give some method to open multiple files .
Message 7 of 14
(7,897 Views)
If you don't need your motion stuff to be synchronized with the VBAI inspection (i.e. just get the latest results from VBAI, but let it run as fast as possible), use the VBAI Start Inspection VI outside the loop instead of the Run Once VI inside the loop.
Hope this helps,
Brad
Message 8 of 14
(7,883 Views)
Hi all,
do you met with the problem to get measurements in labview from vbai ?
I get no error, not empty measurements, but no data.
Message 9 of 14
(7,867 Views)
If you call the get measurements, make sure you call the enable measurements VI before you run the inspection.
Message 10 of 14
(7,864 Views)
