Machine Vision
image control
Hi, I need to input a image(JPEG) to my front panel. I would use image control nodes to control the brightness of the images. However, I can't input the image directly. Any inputs appreciated.
Message 1 of 16
(6,356 Views)
Can you explain a bit more clearly of what you mean by "input the image directly". You can use an "imaq read vi" to read the image.
Message 2 of 16
(6,355 Views)
Basically, I need to insert a JPEG image on the front panel. I will use the data from the JPEG image and process it such that the new data is going to change the brightness of the new image file.
i found how to import a JPEG image. see below. Now I need to process the new picture data to modify the brightness and contrast. Any inputs?
Thanks.
Message 3 of 16
(6,354 Views)
You can vary the pixel valu like this. I will post a more precise way in the next one.
Message 4 of 16
(6,345 Views)
This example shows how you can manipulate each color map independently. You can use this frame work to do more advanced image manipulation.
RGB CMY Color Editor for Jpeg
-Hunter
Message 5 of 16
(6,308 Views)
I've used Vision functions to modify a colour image. If you want to extract info from the image in order to set BCG for each colour then it is pretty straightforward with other vision tools. A mono image is obviously easier to work with.
Simon
Message 6 of 16
(6,293 Views)
Apologies - I attached an image rather than the vi. Here is the vi.
Simon
Message 7 of 16
(6,279 Views)
I feel the op doesnot have vdm installed. using read jpeg instead of imaq read lead me to think so.
Message 8 of 16
(6,277 Views)
I suspect you're right. I just wanted to highlight the possibility of using vision commands as this tends to make life a bit easier.
Message 9 of 16
(6,274 Views)
Yes lightWorker is right and using VDM will simplify the proceedings to a great extent
Message 10 of 16
(6,272 Views)
