Machine Vision
image control
I'm able to adjust the brightness of a single image. (using IMAQ BGC lookup). Infact I m getting very good results with it (there is also a example in example finder).
However, I need to control the brightness of images from webcam on real time basis.
I have posted this request on a seperate thread.
http://forums.ni.com/ni/board/message?board.id=170&thread.id=481599
Please share any inputs you might have.
ABM
Message 11 of 16
(2,089 Views)
I am using an IDS USB uEye camera - cost apprx £200. This came with LabView software for controlling the exposure and was pretty easy to set up and incorporate into my own application.
I don't suppose your web cam has an SDK?
Simon
Message 12 of 16
(2,086 Views)
I need to change the color of an jpeg image. The image is fixed color say Red. How can I change its color to some other color based on changing the RGB conents.
I can't work with any VI's to change the image color.
Any help will be appreciated.
Message 13 of 16
(1,931 Views)
Message 14 of 16
(1,931 Views)
Accepted by topic author ABM26
What do you mean you can't work with any VIs to change the image color?
Try IMAQ FillImage.
Christophe
Message 15 of 16
(1,916 Views)
Thanks...I was missing some basic stuff.
Message 16 of 16
(1,886 Views)
