Machine Vision
image restoration
no,thank you all the same!
Message 11 of 15
(1,642 Views)
Didnt help????
Message 12 of 15
(1,640 Views)
Hi!How can you do this?Do you have this algorithm?I'm using Labwindows/CVI isoftware research image restoration projects,can you help me?
Message 13 of 15
(1,467 Views)
If under "image restoration" you mean deblur (and if blurring function more or less known), then you can try to use Wiener filter.
I just posted simple example here: http://decibel.ni.com/content/docs/DOC-13702. Written for LabVIEW, but formula node was used, so you can program this algorithm in same way in CVI (will be a little bit tricky with FFT and Complex type).
Common theory is here: http://en.wikipedia.org/wiki/Wiener_deconvolution
Andrey.
Message 14 of 15
(1,442 Views)
Thank you very much! But  I use CVI software ,not Labview.I need CVI wiener filter algorithm.
Message 15 of 15
(1,428 Views)
